It is currently Thu Aug 21, 2025 1:41 pm
 Post subject: tuners
PostPosted: Mon Oct 21, 2013 10:19 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Are there any real difference between Taiwanese made, Chinese made, or expensive tuners like those 500 dollars/set tuners? I'm looking for cheap tuners and I usually use those gotoh sealed machines that costs around 30 dollars a set but was wondering if the cheaper Chinese ones are similar in quality?
Typhoon Guitars
 Post subject: Re: tuners
PostPosted: Mon Oct 21, 2013 10:56 pm
When Schallers got too expensive, I started used Gotohs...
PostPosted: Tue Oct 22, 2013 12:19 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So basically the lower tier is so bad that it falls apart? If it's 35 dollars I might as well go with Gotoh, at least I know they are good enough. I've seen cheaper Taiwanese tuners but I do not know if they are the worse one.
Typhoon Guitars
PostPosted: Tue Oct 22, 2013 4:56 am
Mostly in live, you get what you pay for.....
PostPosted: Tue Oct 22, 2013 10:32 am
It's the consistency that is of value. Gotoh is very consistent. I have used some cheaper chinese ones (definitely would not put them on my guitars) that worked okay, although a little rough, and then downhill from there.
